vt6spd ..have u even rooted yet???
here is the app you need.. once you have rooted.
Wireless Tether for Root Users - Android app on AppBrain
bit if you have root... then you might want to get a custom ROM and spice up your OS... which most come with a solution for you.
leave your wifi .. off.
the app will take care of it.. for you.
only way to see.. is to try it. test it out.
you are rooted...
you are using wifi-tether..
you can surf on tethered device .. no connection charge should be seen.
but you might have data charges.. of course! unless you have unlimited data. there is no way around the Data usage charge (depending on your service contract)
use titanium backup to.. put everything back...
dont delete things.. if you dont know what it full does. somethings are tied to many other things.....
Titanium.. has a freeze program feature. freeze what you want to delete... for a few days. if it dont have any bad after effects... then it is ok to remove.
...hahaha... i dont use titanium...so cant tell you how.
suggestion.. this might be a good time for you to look at one of the ROMs.
flash a rom.
