Hot?
timbo3031
Just got my Charge last night. It was getting pretty hot today when messing with it trying to figure it out. (Android newbie here). The back was hot but so was the screen. Is this normal?
Also accidentally deleted voicemail icon and can't find it to put it back. Any suggestions?
Battery only lasted a few hours today before charging. Hoping it gets better over time. When I checked what was draining battery it was 89% screen. Set to auto bright. E- mail set to push but no apps running.
In time things will get better mine did that for the first couple days but now its all good. Your voicemail icon should be in the app menu as for the screen if you keep messing with the phone(which is normal) then it will read that percentage let phone fully charge without you doing anything on it.
