Root Hotspot blocked?
K
K_M
Guest
Is there any way to bypass this block? It'd be nice to use the system hotspot app rather than using another from the Play Store
Plus I noticed you had your WiFi turned on. Its grayed out when you are not mobile data and your not on 4g.
