That is ridiculous!!!!!!!
Do it for free. Just dl one of the apps from the market. Or root it and then use one of the other apps from the market.
Do you have a laptop without WIFI? That would be the only reason for using USB tethering.Can you USB tether without any additional charges and/or software? Or, do you need to use something like PDANet and if so, do you need to root in order to install PDANet?
Or AZLink.You cannot use wireless tether without either paying Sprint for their hotspot feature or rooting. You can tether your device however without rooting. Download either PdaNet or EasyTether and follow the setup instructions.
