verdegallardo
Just curious as I'm trying to figure out what plan to get in advance. Who here will use one of these options and which one? I'm guessing the main difference (besides saving $210 a year and having no 2gb cap
) is PDAnet is wired and hotspot is wireless? I don't see that as a negative since you'd probably want to charge the X while in hotspot mode anyway.
For anyone that has used PDAnet before - does it work well? Ie, would the speeds, connectivity etc be the same between the official hotspot feature and PDAnet?
I have a VZW wireless card right now (so I can go online while on the road) on a month-to-month contract that costs $59 a month!! I'm going to be canceling that when I get the X!!
Thanks
) is PDAnet is wired and hotspot is wireless? I don't see that as a negative since you'd probably want to charge the X while in hotspot mode anyway.For anyone that has used PDAnet before - does it work well? Ie, would the speeds, connectivity etc be the same between the official hotspot feature and PDAnet?
Thanks
