Help hotspot problem
ainzwurth
Hello all,
First post. I have done the ##778 process. Everything is done correctly. Worked great at first. Not none of my 3 computers can connect to the network. I don't use it much. Only a few minutes here and there.
Thanks,
Richie
Have you done a *228 option 1 lately? If so that resets the ##778 setting and you have to re-do it again.
Edit: Just checked it and its working for me. I am typing this on my Netbook using the Hotspot now. Re-check your ##778 settings again. Make sure you are in edit mode.
I did do *228 but changed it back afterwards. The phone started messing up and force closing every apparently I tried to use so I did a factory reset. I changed it back after that. Still no luck.
