Root How am I bricked
EricHHR
So I am apparently bricked and can't figure out how to get back on of it. I was trying to go from cyanogenmod to liberty and I noticed bootstrap wasn't on the apps list. So I redownloaded installed then rebooted the phone trying to get into bootstrap recovery and then it gives me the big battery logo with battery percentage. So I unplug pull the battery and let it boot back in android and now I get stuck in the cyanogen bootloop. and will not boot into android. Try to manually boot it into recovery and get the android with the green triangle any idea what my next step it
Trying to do and rsd on it now but the it keeps saying starting RSD protocol support. Will not work.
Uninstall RSd and download an older version. If your using 5.4 switch to 5.3. The same thing happened to me and I tried a different rsd and it worked fine. Especially if your sbf'ing to 2.3.4
