Accessories How Big Is Your Battery??
JSS12
Hey all,
I have had my DInc since launch and I am still struggling with my stock battery to get through a full day.
It is finally time for me to order a bigger battery.
I want to know:
1) How big is your battery?
2) How long does it last you?
3) Please classify if you are a light, medium or heavy user
(I will not judge you if you leave your phone on airplane mode all day or if you drain a 3500 in one hour)
4) Size is important to me (like all guys) PLEASE POST A PICTURE OF YOUR PHONE WITH YOUR EXTENDED BATTERY and comment on whether or not you find the size an issue.
5) What kind of a BACK do you have for your phone with your new battery?
THANKS in advance!!
Kinda a personal question don't you think?
I have a 3500mah with the extended back from ebay. I can get over 24 hours when I bump charge it.
I'm using a 1500mah battery with a stock back it lasts me a day and a half medium user
1750 seideo (really a 1500) and lasts me maybe 11-12 hours after texting a good amount all day. then again, i believe my battery life SUCKS and it's pissing me off lol
ANYONE HAVE PICTURES??
Also,
HOW MUCH DID YOU PAY FOR YOUR BATTERY??
just trying to gauge how much it will cost me
THANKS!
I have a 2600mah($15 on dealextreme.com) which is intended for the htc Diamond 2. It lasts about 50-65% longer than my stock battery. I think I have a photo on flickr. I will try to dig it up tomorrow. I just cut a hole in my back plate and let it hang out. I rarely use it these days as setpcu and data off when not needed gets me through the day.
Here are some photos I posted in a previous thread. My macro lens attached as well.
http://androidforums.com/attachment...20950-macro-lens-attachment-phone-w-wide.jpeg
http://androidforums.com/attachment...-macro-lens-attachment-phone-side-w-wide.jpeg
http://androidforums.com/attachment...0950-macro-lens-attachment-phone-w-macro.jpeg
4) Size is important to me (like all guys)​
First off, Thats what she said.
Now that we got that out of the way. I have the 2150, and its a great battery, its from VZW. I like the added thickness, adds a sense of durability to your phone. Im on my second day with moderate usage, at 15 percent, i run airplain mode between 11pm-7am when at work. I also use WiFi when at home. I use setcpu as well to underclock the cpu when my screen is off.
I'm a light user id say some surfing, checking emails, texting and a dew calls. I use the sedio 1750 I get about 29 hours out of it with a bump charge. pictures well its fits behind the stock back.
9 1/2 inches
My whole life!
Heavy....lotsa use
Attached below.....and size is not an issue here...
Note: the black part is the actual phone attached to the battery.....better wording.
No back....big enough.
I have the 1500 from Bidallies. You don't need a picture since the battery fits within the stock back cover.
My phone will last from 7 am until 10"ish" the following night. So 2 days, 1 night. With moderate usage.
Keep in mind that I am also rooted and have modded the hell of out my phone. So much of my "improved" battery life isn't due to the battery itself, it's due to my own changes and adjustments to the system.
