How bright is your LED indicator?
Eshyn
Since day one I've noticed that my LED indicator is fairly weak. I pretty much have to be standing directly over the phone to notice it as it's virtually undetectable from an angle. And forget about being able to see it from across a room.
I'm coming from a Blackberry that had a VERY bright and noticeable LED notifier.
Given, I do appreciate the battery life I'm sure it's saving by being a bit on the weak side. I was just wondering if this is common or perhaps mine is defective?
Thanks!
I agree. I wouldn't say that the LED is weak but is very recessed under the top layer of glass. My brother has a Tour and the LED is very clear and obvious for notifications. It's a small deal ultimately but it can be annoying.... I just wish I didn't have to wake up the device from the top..
The original droid had to be woken up the same way. I dont mind it. But I did love that I could see if I had a message from across the room.
Mines is the same. Very dim and if you are looking at it from an angle, don't even bother.
