Help How can a gold card be checked?
sameee781
I've just crested a 2GB microSD card as a gold card. How can I check the microSD card is actually a gold card? Let, I've 2 microSD (2GB) card and one of them is a gold card. If there is no physical marking on the card's body how can the gold card be differentiated? Any idea??
:p
How can I check a microSD card is a gold card?
Connect the phone to a pc via usb and press mass storage on the phone when it pops up, then on the pc, go to the drive that is the micro SD card and if it has nothing on it you should see only the gold card, or download astro file manager from the market and search for it through that, its very very simple to do, the gold card process doesn't do anything physical to the card, its literally just a small file on the SD card.
