Root How can I change CDMA / PRL Numbers?
AlexMason
How do I change all the number to disable my phone from connect to cellular towers. I dont want a fix that can be toggled in settings I want some that the average joe couldn't fix without know what actually happened.
Yes I know messing with these numbers is dangerous... I want them changed for a reason.
Are you asking for this info for your LG Ally? If so, you are in the wrong section of the forum. I am pretty sure there is a way for Motorola phones, since we can change that info to get say a A855 from Verizon to work on Cricket, Metro and a few other CDMA carriers.
Well, then I am pretty sure the method/software to do it would be similar to and or contained within the same information to change the service programming, as that is basically what you are wanting to do. There's a huge thread on that over at Howard Forums. I'll give you a link to one person's site that has the info. It also has the link to the thread. As far as the software you'll need, I believe I have it.
android - whiterabbit.org
good luck
