Root how can i flash a prl on my evo?
The easiest way to update your PRL is to be sure you're on a Sense Rom. Then go under settings / System Updates / Update PRL.
everytime i try i get online problem
what exactly are you trying to do? if you just need to update them then you can do it in your phone's settings. you can't flash prl.....at least i have not seen anything specific for the evo 4g lte like there was one for the og evo.
