Help How can I make my phone faster ?
There are many different things you can do.
First, root your phone http://androidforums.com/ascend-all-things-root/254599-step-step-rooting-instructions-huawei-ascend.html.
After this, use that same guide to uninstall all your "bloatware".
That will speed it up some. If you still want more speed, which we all do here are a few things i learned from these forms that will help you quite a bit.
  • Install Launcher Pro
  • Install Dolphin Browser.
  • Turn off your wi-fi / bluetooth when you are not using them.
  • Install and use cache mate.
  • New keyboards are a minor upgrade..
A big thing I have found is you get what you pay for, so dont try to run 15 apps at once and have them all run smooth. Stick to one, maybe two at a time.
Hope this helps!
