Is there a separate meter to tell what is left in the dock verse the transformer? the percentage doesnt seem to change when putting it on the dock and taking it off.
Get the dual battery widget.
https://market.android.com/details?id=app-org.flexlabs.widgets.dualbattery
I downloaded the widget from the link and installed it. Odd thing is, it doesn't show up anywhere on the TF. Shouldn't it be with the other widgets under the + sign on the home screen? Any help would be appreciated.
I did use the market version. After I rebooted the widget appeared. I hope others don't have the same problem. Thanks for the help.
If you had read the install notes in the marketplace you would had seen the note to restart after install.
