Help How can we get GTA3 to work on ZTE N861?
cvic
I played around a bit with the game on friend's Xoom and then bought it, used it for a few days with no problem, then i flashed a ROM and now it says the game is incompatible...
I'm not concerned with flashing back, so how (if possible) could I make the game work? I thought maybe using apkextractor to get it from the Xoom might work, but I havent had the chance to yet. I'm guessing it has something to do with the game not running at a proper resolution, so they just marked it incompatible but f that. I know someone can get this working
The compatible device list for the game I would say is embarrassingly short... like literally less than ten devices.
