G
gregtrips
Guest
Is there a specific app? I was thinking either through the SD card or USB cable. But, where would I put the files in? I can't seem to find a directory labeled MUSIC.
Anybody have some tips and tricks for LG Optimus V consolidated some where?
Some of the best tips you can find are right in the user manual.![]()
After I learned you need a Music folder for your files. I found out the best way to organize your Music and get the Album Artwork to show.
SD> Music> Create new folder with an Album Title (i.e Angles)> Your mp3 files in here, along with the album artwork (i.e. Angles.jpeg)
Create a new folder for every album you want in your Android.
