Help How do I assign a downloaded ringtone as a text alert?
gocardinals
I am able to download a ringtone from Zedge, but how can I get it to say a SMS alert tone or a Facebook alert tone? The only options that show up there are the preloaded sounds.
Create a folder on your sdcard called "media" then within that folder create a folder called "audio" and within that folder create another folder called "notifications" then put the audio in there. They will now appear with the preloaded sounds
I really appreciate your help! Where do I go to create a folder? Hopefully this is the last time I'll bother you. Sorry.
