kris0933138
Im trying to install a new rom. i have a lg optimus M and its rooted just wondering how to get it into recovery to do that
Make sure you install Custom Recovery first. The phone doesn't come pre-installed with any kind of recovery menu. Some people end up wiping their phones not realizing they have to install it first.Im trying to install a new rom. i have a lg optimus M and its rooted just wondering how to get it into recovery to do that
Use these two threads: http://androidforums.com/optimus-m-all-things-root/349438-guide-how-flash-recovery-easy-way.html & http://androidforums.com/optimus-m-all-things-root/355703-guide-rooting-procedure-step-step.html to get you started.ok .. how to i create that ?
It sounds like you are missing a chmod command that will change the permissions on the file before it's installed.i tried what you said first just now it say cannot create /system/bin/flash_image is read-only file
Here ya go.ok will try doing it with that tutuiroal. how do i get Adb ?
If you haven't done so, you also need to download the drivers for your phone and install them before connecting your phone.ok all installed. so now how do i open it
Don't put the .zip on the SD card. You extract flash_image and put that file on the SD card.ok thank you so i have recovery-RA-optm-2.2.1-GNM download and flash_image.zip both on the root of my sd card. so my question is do i now open adb? its install taking a little time.
