Help how do I change default url behavior?
gamul1
When I clicked on a link in my email it asked me which browser I wanted to open the link with. I selected the option to always do this in the future and then proceeded to accidentally select the wrong browser.
How can I change that so it asks me again?
Settings -> Applications -> Find the application you set as the default, and click "Clear Defaults".
If you set the default as the stock "Browser" you'll have to go to the full list of applications ("All") instead of just the "Downloaded" applications.
Thanks! That worked perfectly!
