I currently have FlyX installed with a theme on it. Can I just put the new theme.zip on my sd card and apply in the recovery like the last one or do I have to remove the current theme and then install it?
Thanks
Ideally you would have made a nandroid backup of your phone before you applied any theme. Then you'd just go back to that and then theme to whatever. If not, I'd suggest SBF with all due precautions
Dont sbf. Just use the rom manager to re install fly x first. Hell just put the new theme on and see if that works first. If too much stuff is left from the last one, then re install the fly x nandroid from rom manager.
