Help How do I clean my screen?
What should I be using to wipe down the N 7 screen ?
I've been good so far just using a clean paper towel and doing a dry wipe / polish. No cleaners or anything. If you are going to use a tissue, make sure is isn't one of the ones with aloe in it as that will streak.
:D
I generally wipe mine with the edge of whatever clothing I'm wearing. My sweat shirt seems to be particularly effective.
