go to contacts. at the top there should be a bar that says conacts: all contacts, tap on it. then tap create new group > type in the name of the group and add the contacts to it. then tap save. once it saves it should take you back to the contacts menu showing you all your contacts. tap on the bar at the top where it says all contacts again and select the group you made. you should now be in the group along with the members of it. in the top right hand corner below the dots there should be a pencil and paper icon. click on it to send a mass text message/email to all the contacts in the group
