Help How do i delete ring tones on my captivate
Any ringtones that you added are found in the media\audio\ringtones folder of your sdcard, if you want to delete the original ringtones then i don't know.
I went to the Media Player app and found them there and deleted them. So easy ... don't know why complicated some make this. Was a pain trying to find this simple solution. Good luck to all of you needing this same thing.
