Help How do i disable the front camera?
Davicii
My galaxy note 2 was recently repaired do to a broken screen. Now that I have it back with a replaced LCD screen the front camera wont work. It is probably a hardware problem but I dont want to wait another couple of weeks for it to get fixed.
Now everytime I want to use the camera app or other apps(like instagram or snapchat) it just tells me that it cant connect to the camera and kills the app. How do i set the phone to using just the back camera for every app?
You need to get into the camera app to change the camera.
Try a hard reset and see if that fixes it. If it doesn't, take it back to wherever you got the screen fixed and tell them the problem.
