Help How do I disable the shutter sound?
Toxx Synn
OK, so I successfully rooted my M840, and I went in using Root Browser and deleted everything that said camera in system/media/audio/UI and the camera still makes the shutter. Any ideas on how to finally get rid of this annoying shutter? Thanks in advance.
Hello you just answered my question with out even knowing it, if you could toss some guidance my way on how you rooted your prevail 2 highly appreciated bro I been getting nothing but dead end results n answers need help please
See my other comment, tells you exactly how.
I used root explorer but I'm sure it can be done with others. First go into system folder then to a folder called csc, look for feature.xml then press and hold it until the sub menu pops up now press on "open in text editor" , in text editor look for "CscFeature_Camera_ShutterSoundMenu>false<" once you find it delete false and type in true so it would look like this "CscFeature_Camera_ShutterSoundMenu>true<" then back out and save and exit. Now restart your phone and in the settings in camera now there's the option to turn shutter sound on or off.
OMG OMG OMG Thank You !!!!!!!!!
Someone help me do this! I seriously no freaking clue how to even begin. Please help! :(
Hello keerstinhaley,
If you hadn't already done so here's a step by step on how to enable shutter sound menu in camera setting to disable sound Since rooted get the app Root Browser the logo is black folder with droid head or whichever you prefer go into your system folder look for feature.xml scroll down till you find camera features and find "CSCFEATURE_CAMERA_SHUTTERSOUNDMENU>FALSE< delete the word false and input true so it looks like this ------>CSCFEATURE_CAMERA_SHUTTERSOUNDMENU>TRUE< HIT THE SAVE BUTTON AND EXIT GO TO CAMERA HIT SETTING YOU SHOULD HAVE SHUTTER SOUND MENU OF NOT REBOOT THAN YOU WILL SEE IT N CHOSE DISABLE... HAPPY HOLIDAYS :-) HIT THANKS IF THIS HELPED
Hello Toxx Synn and fellow androiders. HNY! Does anyone have a good custom rom for the prevail 2. If so please help a novice out. Thanks.
I've done this and still nothing.. any other ideas? When I checked back to where It was edited, it reverted back to false. HELP
