Help how do I downgrade my phone?
H
hello123345
Guest
hello, I have an alcaltel one touch idol 2s And I recently made the upgrade the system wanted me to do but since then my battery drains like super fast, how do y un do the upgrade? apart from draining my battery it didn't change anything on my phone. it's the 4.4.2 upgrade
Enter recovery and clear the cache partition.
If that does not solve the problem you may have to
backup your apps and data and do a factory reset.
