When I click the portable hotspot under settings, I get an error telling me to call virgin mobile. How did you get wifi hotspot functioning
I forgot to mention foxfi supposly enables tether without the data package I would try it its free on google play store
I logged onto VMUSA website today. They have a link on the right to enable the mobile hotspot.
Thanks everyone for your assistance.
I noticed that if you click on the link on the website, it gives you a choice to permanently enable the hotspot or to only enable it for your plan current month. While it seems somewhat of a waste to only get the remainder of your plan month (especially if you go halfway through the month and then need to use your phone as a hotspot), I can see an advantage when you get a message that you are close to your data limit and then switching the hotspot on so you get the extra 1 GB of data.
Android wifi tether works, pick generic ics, clamp and reroute. MUST BE ROOTED.
Don't Pick Evo 3D in options
