Help How do i forward a contact via text msg?
The best way to send a contact thru text is to select the contact(s) in the "To" field of a new msg and then copy it from there and paste it into the message field. This way ul have the Name and No.
Dont think there is anyother direct way to do it.
You download an application, 'Ciacs' from android market & it will let you make buissness cards for sending aswell as read the text msgs to be converted into a buissness card that can be saved to contacts.
