Install ConnectBot. It has a LOCAL feature and you'll see a "$" prompt and after typing 'su' you get the SuperUser prompt from unrEVOked, and after that.... *drumroll* you should see "#"!!!
"id" reports uid=0(root) as expected! w00t!!
Now, can anyone recommend a good and FREE SSH daemon and web server for this thing??
For SSHD, can I just do this (Dropbear) now that I'm root? Is it ported properly (will it work)? http://www.droidforums.net/forum/droid-hacks/9038-ssh-daemon-dropbear-android-2-0-a.html
