if youre talking about in your texts its;
the far left hard button on the bottom under screen, then insert smiley or more/insert smiley.
if you mean on your desktop etc./there are multiple ways most likely. flashing a theme with them (now im assuming you are rooted and can flash themes).
if you are rooted, it wouldnt be hard for us to take whatever theme you are running and custom make you what you wanted by adding the icons of your choice in to your theme and flashing that.
if you arent rooted and want to be, that wont be hard to get you through either.
