Help How do i get live wallpaper?
kevinrubio
Android Expert
so i had this live wallpaper on my 2.1 ascend phone - https://market.android.com/details?id=fishnoodle.storm-- so when i clicked on that wallpaper, the clouds were dark and cool, but when i updated to cm7 and tried it again, the clouds were gray and really weird, and i know its not the settings because i copied the settings from my old to new, and yes i tried re-installing it, so can anybody help me with this issue, because i really love this app/wallpaper.
So the option of Live wallpapers is not there when i hold the homescreen and click on wallpapers, how do i get that folder back?
It sounds like you've deleted the 'live wallpaper picker' apk. Check the 'Stickys' @ the top of the ASCEND forum for information on it.
I was guessing that the 2.1.1 live wallpaper picker apk would work on any ASCEND,regardless of which O/S is installed.
My apologies if this suggestion caused any problems or confusion.
Glad y'all have your live wallpaper re-installed. :)
Wanted to try out live wallpapers to check out their effect on battery and performance. Im on Cm6 and was wondering if my phone could handel it now.
Anyways, both links seem to be down, any mirrors/other places I can get the live wallpaper picker back? Thanks in advance.
why not use the second link in my upper post...
Live wallpaper picker is installed. Problem is the live wallpaper that I linked isnt working. Its saying "loading Live Wallpaper". but it never loads. Wondering if its the wallpaper or my phone?
well if its for an hdpi phone, it will not work for you, the ascend is mdpi...:o
