As the title says. I want it to give me repeat notifications after i miss a call, a notification when someone leaves a voicemail, and repeat notifications if I have unchecked texts or e-mails. Thank you.
Lightflow (app) will do all of this for you. Just don't check the option of the additional LED (S6e880 LED or something like that) cause the app bugs. Otherwise works great for notifications, reminders, etc.
Not only can you set it for repeat reminders, but the interval, LED colors, vibration settings, and it works with almost all your apps that need notifications of any kind.
