Help How do I get WiFi, Mobile, GPS icons?
gocardinals
I just switched to LauncherPro Plus, and now I can't find the wifi, mobile and GPS adjustable icons. Are they available in LauncherPro, or just Sense?
Thanks.
If you're talking about the toggle widgets, I do believe they're sense-based so they would no longer be available. There are many widgets in the market though. Or you could use the power control widget and attain the same functionality.
Thanks...the power control is close. Is there any way to see what they are, though? I know the wifi, brightness and bluetooth, but what are the other two?
