secrecyguy
Member
I replace my Motorola Triumph with Kyocera Rise. To my surprise, it's actually so much better with all the problems Triumph has.
This is just a minor problem and I don't know if there's a solution to it. I use a old GPS Tracker by Instamapper on my phone. I have a feeling it's no longer supported since the website and the app haven't been updated for a while.
What I have noticed, the new phone actually disable the GPS Tracker after couple of hours of running in the background.
I try to disable the Eco Mode but that seems not to work.
So is there a solution to this problem? Thanks!
If not, is there another program I could use and that is free that is a good replacement for GPS Tracker?
