K Karzzy Newbie Jul 16, 2010 #1 name in the unlock pattern page which had a text saying This phone belongs to: Thanks in advance!!!
nacatomi Android Enthusiast Jul 16, 2010 #3 Not sure cos I dont use unlock pattern but I would hazard a guess that it would read what you have entered in your contact card in "People"
J jred7469 Well-Known Member Jul 16, 2010 #4 if you have the antivirus app installed it is in the settings there I uninstalled it becuase after an update it scans basically your whole SD card everytime you mount it and it was getting so annoying!
K Karzzy Newbie Jul 19, 2010 #5 jred7469 said: if you have the antivirus app installed it is in the settings there I uninstalled it becuase after an update it scans basically your whole SD card everytime you mount it and it was getting so annoying! Click to expand... Thanks for the tip buddy.
