Ok so how do I install a custom recovery?
Please and thank you
There is no CWM for this phone? How come there's talk about it around the forum? When I boot into recovery (vol+ and Power) I get the Samsung recovery. Apply update and stuff. No CWM? Weird.
The recovery is tied to the kernel on this phone. So If you are on ICS (FL24 being the newest build for that) then the Agat 0.6.8 kernel referenced in the rooting guide will work for you.
If you are on build GC01 which is Jelly Bean then the one from here will work:
[KERNEL][JB][SOURCE][BST] GC01 + Agat's Recovery
Note: If you are rooting following the rooting guide and you are on GC01, then you need to use the kernel linked above for GC01. Agat 0.6.8 is for ICS and will not boot JB
Hey codegerm thanks a LOT for the small explanations for the builds and how the kernel is tied to the custom recovery. This thread really should either get stickied or plugged into the "all-things-root" guide. I wouldn't have written my own thread if I could've found this one earlier. Just knowing this little bit sets the foundation to move forward on everything.![]()
I'm glad you found the posts useful.
As a side note I have fount that the file links on the SXTP site have been down for the Garwynn's JB kernels. If you happen to be on GC01 you can use the ones for GB27 just fine available from the repository here
Rwilco12's Android Repository - Downloads
I recommend either version 0.4.1 or 0.5.0 earlier versions had issues.
Right on. So the build is tied to the kernel number as well as the recovery. GB27 is still JB I assume. If so is there any functionality difference from GC01? Thnx for your time
Mr Smooth lol whats up dude, good to see yea in here sir.........![]()
Very cool to hear you got a GSII, you will love the phone sir and there are some great roms for it...........:smokingsomb:
I'm open to your expert opinion on a tw jb rom to try if ya have any! I specifically picked this phone because of the roms and development.
I would suggest this and ask the guys and girls, they will tell yea how great this rom is lol.....
http://androidforums.com/galaxy-s2-...t-x-v2-5-team-rejectz-updated-07-09-13-a.html
That'll be the first one I try then![]()
