How do I install NeatROM 4.8?
alanthor
Hi, i recently rooted my phone, using the dummie guide here. I have a SGS2 i19100, and I want the NeatROM 4.8. My Android version is 4.1.2
I have downloaded it, but how do i install it?
Please, quick replys would be VERY appreciated.
Regards
Robin
I hope im doing this right. I put the rom in my sdcard, went into CWM recovery, wiped data/factory reset, then i installed the ROM from sdcard
edit: Im stuck on NeatROM boot loading page...
hi alanthor,
do what ironass suggested.
if problem doesn't sort out then try following:
1. go to recovery
2. wipe cache partition
3. wipe dalvil cache
4. Wipe Data/factory reset
5. format /system
6. format /preload
7. then again try to flash NeatROM from ur internal SD card
8. reboot
see what happens.
if u again get stuck on boot then maybe u had a bad download.
if u have any other firmware downloaded (non stock) and copied on phone internal sd , then try to flash that from recovery.
otherwise, go to download mode and flash stock firmware via odin.
then re-root and again download NeatROM and flash.
