If your installing your own pc you have to use the crop if you didnt know it lets you make the crop size bigger.Just click on it and drag it.
Also if your pic is bigger than the crop size then it wont fit on the screen right anyway.So i will recommend if the pic is to big just resize it to these dimensions 960
