Help How do i make a screenshot
Jockelino
Hi have a SG2
4.1.2
Haven't been able to make screenshot since ICE i tried everything, volume down + power, volume + home nothing works..
Voume+power turns phone in standby only
and using home tab minimizes any program i'm in.
any other suggestions?
I live in sweden incase that mathers in some way..
On the S2 4.1.2 ROM hold the Home and the Power button at the same time for 3-4 seconds, then the screen will flash and you will get a notification saying "Saving screenshot" and it is saved in the clipboard at first !
Doesn't work on 4.2.2 though.
Screenshot It! FTW
