A.Nonymous
Extreme Android User
I can't figure out how to turn off a2dp. In my car, the DInc is plugged into an FM transmitter and paired with my BT headset. The problem is the audio I'm playing comes through my headset instead of the car stereo. No problem says I. I go into the bluetooth settings for my particular headset while it's paired and uncheck the box that tells it to play audio through my headset. Problem is solved. Wrong. The setting doesn't stick.
The next time I got in my car and paired my headset, it started playing through the headset. This time I dug through the menus and made doubly sure that I had ticked the box. I backed all the way out to the home screen and the setting seemed to have stuck. Then I went all the way back into the menu and the settings again. The setting was still there and seemed to have stuck. Wrong. Turned the headset off and turned it back on again. Same thing. A2dp turned back on. How can I permanently disable this? I'm using a BlueAnt T1 if that makes any difference.
