Help How do I remove the battery?
darklide
I just got my Atrix put the battery in to make sure everything was good and now I can't get the battery out to get the sim in!
Is there any special way, I tried pulling where the tab cutout is.
There is a small notch at the top right to pull it out. It is immediately above the trash can symbol. It is pretty tight so you just have to use a little force.
Nothing special...just look at the little image on the battery cover and it shows which way to push it and flick up with your fingertip or nail. It only takes a mild push to get it to pop out on my phone. If yours is stuck, then it probably wasn't in all the way or something else is jammed in there with the battery.
