hi,
i just recieved the 9.7" pendopad 4.0 through dodo and instantly noticed theres no google play and will not allow me to access it through the web. i have been told i need to "root" my pad but none of the methods suggested to me so far have worked. im not a very technical user so if any responses can be made as easy to understand as possible that would be great.
if there is a way of installing google play without "rooting" im happy to try that but if rooting is the only way then i just need some simple step by step advice, for a novice, on how to do this.
thanks guys
thanks guys
