Root How do i run recovery? It doesnt do anything
I believe from there you hold the Volume 'up' key and press power. You can then select the .zip to apply.
Thanks, but in my post I already mentioned i did that, and described what it does after i select recovery....recovery is not a zip, Im referring to the recovery menu when you restart your phone into recovery.
I was referring to the point at which your phone was at the Red Triangle-Exclamation point screen - have you tried holding Volume 'up' and pressing power on this screen?
Sorry for the misunderstanding - your initial post is a bit unclear the order in which you perform your actions.
Sorry, yeah that was what I wasn't doing, I went back to the out dated thread on how to root and saw that I was suppose to hold vol key up and pwr on that screen as well, and now I saw your response.
Thanks
disregard, figured it out
I'm glad you figured it out - but it may be beneficial for future users to understand the circumstances and the fix for the issue. This helps in Google searches and keeps the redundant thread count down.
Just letting you know since I seen you have deleted your original post. :)
