Root How do I save .apk files?
M
Member113588
Guest
I heard that once you root your Android phone you can save the .apk files from the android market for backups. Is this true? If so how do I do it?
IF you're new to rooting your best option would be to use Titanium Backup until you learn to play with adb shell via command prompt.
I'm also new to being root of my phone so thanks for the advice i will take a look to the app you're suggesting :)
