Well guys I am a newbie to the Android world!!
On my earlier Nokia I used to have three options for the Network Mode under the Phone Settings, viz. , Dual Mode, UMTS, GSM. Since in my area the 3G signal is a bit weak I used to select UMTS only, so that the phone doesn't switch over to 2G automatically.
However, in my android device (GT-I5503) the only option under the Mobile Networks which is anything similar to a Network Mode selection is the Use Only 2G networks checkbox. I believe it disables Dual Mode and allows GSM network only, in the Android device. So Android Gurus and Forum Moderators, do you guys know of any method or software which can select 3G network only!!
Please help me guys as the 3G reception in my network is a bit weak, Android doesn't switch over to 3G!!
Oh and BTW, I'm getting a really good 2G signal. The Signal Bar is 4/4 most of the time!!
