How do I swap memory with Internal and External SD?
I would like to be able to swap my internal storage with my SD card so I can use my 8GB SD card for games. How would I change the vold.fstab file to swap?
This is the bottom of my vold.fstab file in /etc/system/vold.fstab
#dev_mount sdcard /storage/sdcard0/external_sd auto /devices/platform/msm_sdcc.3/mmc_host
#LGE-UPDATE 20120903, fx1-fs-bsp@lge.com
dev_mount external_SD /storage/external_SD auto /devices/platform/msm_sdcc.3/mmc_host
This guy might be able to do it, or use the info and try it.
Swap internal and external sd card of Any android device
http://forum.xda-developers.com/showthread.php?t=1991583
Thanks, but I have seen that. I have tried switching it around, but my phone still mounts internal storage and SD card as normal. This is what I tried...
I was able to switch my default memory before mine was even rooted in the storage setting. It's why I'm switching back to the Premia from the F3.
did you have to enable anything to get the option under "storage" to show up? I do not have any option listed to swap the internal/external storage
Im thinKing of getting this phone but there's not enough storage if you are able to make the swap can you make a zip to flash via twrp when twrp comes out for this phone btw why isn't there any development for this phone yet? My phone has tons it's the virgin mobile galaxy victory the forums are always full of development and activity thanks for reading
Please, send all code of vold.fstab
Thank's
I tried link to sd twice an it caz my phone to log an took awhile load di apps and my system ui asked me to delete my second partition so i wud really recommend u to try dis way caz it's alot better to jus swap ur external SD wit ur internal SD: http://youtu.be/-ASD40Zk1bA
