Root how do I take a screenshot in mobster?
justbenny2k
I'm running Mobster Barebones v1.6 and I can't figure out how to take a screenshot with it. Neither home+power nor volume down+home works.
Just hold the power button down and you'll get a pop up menu and there will be a screenshot option. If not, then try enabling it with leedroid tweaks.
not currently running the rom but try holding the power button and the power off buttons show up... there should also be a screenshot button... if not... go to leedroid tweeks and there should be an option (i think its in misc) for items that show up when you hold the power button... and make sure screenshot is checked
edit: ENVi3 beat me 2 it...
That's great! The power down button is exactly what I was looking for and there are all my sound profiles, too. Thank you so much, guys. Now if I can just get that pesky MMS working...
