Are you rooted ?
Then you'll have to pay for an app like pdanet
Or clockwork mod tether
What about foxfi does that work?
I'm in Uk and so not on Boost in the US and am not rooted. Using jellybean 4.22 sense 5.0 the settings are in -> Settings -> More -> Mobile Network Sharing
There you have settings for wifi hotspot, USB network sharing and bluetooth tethering.
@lucids
have you been to xda-developers.com?
they have quite a few MODS fir your device, should you ever want to root it.
So foxfi seems to work fine but whatever settings I put on foxfi do not apply to my phone cuz I changed the hotspot name but when I search for it on a 3ds, it shows "HTC Portable Hotspot" instead of the name I put
Install nova launcher and go into the app drawer try using the native hotspot app
it's hidden for whatever reason using the stock sense launcher
Ok now I have a problem with the connection timing out, I used my brothers phone to connect to my hotspot, but it always says obtaining I.P address for like a 1-2 minutes then stops trying
only rooting your phone will allow Wi-Fi hotspot
BUT
you can usb tether with the apps I mentioned
boost doesn't want us sharing our connection
Goddammit boost -.- that only works for computers isn't it?
*sigh* oh well might as well wait for 4.2.2 and root
you can root now, and still be able to receive 4.2.2
I've been rooted since ICS and I'm completely up to date
http://forum.xda-developers.com/showthread.php?t=2450868
[almostRUU][K2_CL]&[How To Update After Moonshine S-Off]
you can follow this guide
just omit the PL80IMG part,
it's as easy as restoring my 4.1.2 backup that I've provided
and then flashing the stock boot.img and stock recovery.img
then you can update all further updates.
and, I'll always be here to help guide if you need it
