Help How do I transfer my number?
DanxD
So I'm getting a replacement phone that will be here on Tuesday and I was wondering how will I be able to transfer my Number to my new Triumph?
It's simple really. All you have to do is get the MEID number of your new phone which is the number under the battery. then you would go to the virgin mobile website and find the place where it says "transfer accounts" or something like that. ORRRR you can just call them up and do it through there. :)
Make sure you do it while it's in stock though. I've heard doing it while using a custom rom doesn't seem to work.
Yeah call them and they can do it for you or online, login to your account and click swap phones and enter all numbers needed.
