Help how do I turn off swipe lock?
picard12
I don't want to unlock every time I check my email. this is annoying.
I already check language input section. I can't find swipe off.
I am using swift key 3 trial. There is no setting to turn off swipe lock
I already set the security section to no swipe but it isn't working.
You mean you don't want to unlock the screen with swipe? You want it to wake up fully when the home button is pressed? If that's your goal, just set you screen lock method to None. It is under Settings -> Lock Screen. Just beware that when the phone is in your pocket, you could be accidentally using the phone to dial out or other things...
